| Home Products & Services About Us Community Forum |
Welcome, Guest. |
This is a community for the planning and discussion of offroad adventures. All makes and models of offroad vehicles are welcome! Multi-day expedition-style trips are our main focus, but there are plenty of day runs, clinics, and tech-days as well.
The forum is free for Basic Membership! Optional Premium Club Membership includes such perks as exclusive professionally organized trips and events. Please note that you may view the forum as a guest, but will need to register in order to post or to access certain areas of the site.
| View Thread |
Thread Tools | Display Modes |
New to the forum thought I would share my rig
03 GC 4.0L Laredo Suspension MX6s, KOR Dual SS Setup, Addco 1" Rear, 3" IRO Lift with Kevins 0.75" Spacers all four corners, KOR Sliders, JKS Quicker Disconnects, D44a Rear Swap, IRO Critical Path Front Long Arms, IRO Adjustable Lower Rear Control Arms. IRO Rear A Arm Spacer, Carolina DS front Double Cardan DS, JKS Tie Rod and Drag Link, JKS Adjustable Front Trackbar with Super Hard Bushings Tom Woods SYE and Custom Rear Driveshaft. 4.10 gears front and rear, ARB locker in Front, Aussie in Rear. Engine 63mm bored throttle body, K&N FIPK with AEM Filter, Gibson Stainless Steel Cat Back Exhaust Exhaust Summit Transmission Cooler and Remote Filter Sunpro Transmission Temperature Gauge Recovery ARB Bumper, Mile Marker SE9500 Winch with Synthetic Rope Mopar Factory Hitch Receiver Mopar TC and Fuel Tank Skid Plates Highlift Jack Homemade 15lb CO2 setup Wheels and Brakes For Wheeling Cragar 15x8 Soft 8s, Treadright 31 x 10.5 x 15 MTs For Street American Racing 17 x 8 Crush Rims with Good Year Wrangler Silent Armors 245/65R17 PFC Pads, Slotted and X-Drilled Summit Rotors all 4 corners W/ GoodRidge SS Brake Lines Electrical Optima Yellow Top to keep it all running Pioneer AVIC-F900BT Double Din Navigation unit with Sirius Satellite, Alpine 250w Amp, Alpine Type S (doors), Infinity 3.5" Tweeters and Basslink Subwoofer 500watt Power Inverter hardwired in 3rd Generation Projector Headlights with 55watt 4300k HIDs and Digital Ballasts on dedicated relays. Cobra Model 75 CB radio and Firestick Antenna Hardwired Cobra Radar/Laser Detector Viper Security System to keep the bad guys away. Misc. Yakima Mega Warrior Roof Rack with extension, spare tire, and tool mounts. Driving lights on roof rack Smittybuilt Gear Seats both front seats |
#2
Early picture with 2" BB and Crush Rims installed, also Westin Bull Bar and Nerf Bars
![]() Post 3" IRO lift install
#3
Installation of double din head unit.
http://www.jeepsunlimited.com/forums...27#post4347027 Initial ARB Bumper Install ![]() Current ARB Setup, control box is under the bumper, plug on front and dash controls as well ![]() ![]() ![]() IRO Front Upper CAs ![]() Rusty's Lower Control Arms ![]() Both replaced with IRO Long Arms ![]() ![]()
#4
homemade bumpstop extensions
![]() Double cardan front DS ![]() ![]() ![]() Rear A arm spacer ![]() ![]() Rear lowers installed backwards ![]() Rear Lowers installed correctly
#5
started adding some pics, more to come
Yakima Mega Warrior Roof Rack installed ![]() ![]() JKS Sliders and Rock Lights, soon to upgraded to LEDs ![]() ![]() ![]() Front Steering Components, JKS Tie Rod, Drag Link and Trackbar (what a PIA to keep tight) and KOR dual SS. Also a shot of the loop I tie my Swaybar up with. ![]() ![]() ![]() ![]()
#6
Rear Cargo and Interior
First aid kit and fire extinguisher ![]() Sub, amps and power converter ![]() ![]() Flashlight ![]() Dash and upgraded switches ![]() ![]() ![]() Under hood: FIPK with AEM filter, Yellow Top, Accessory Fuses and Relays, HID Ballast ![]() ![]() ![]() ![]()
#7
D44a install
Well I have the D44a installed that I got a junk yard. I think I am going to do the hack n tap on the TC output shaft and get a DS made. Also got a classic tube 5th brake line made so all the flex is now SS Braid. ![]() ![]() ![]() ![]() ![]() ![]()
#8
Well just added some rock lights for night crawling, wife got these for me for my birthday, I cut them apart and lengthened them so that there is one behind the axle two along the rock rails and one in front of the front axle. Will post some pics later after it gets dark.
http://www.ledtrailerlights.com/other/cargo-lights.htm Front under bumper ![]() behind front wheel ![]() in front of rear tire ![]() behind rear wheel ![]() Night shots ![]() ![]()
#9
ARB Compressors and Wiring
Added a high out put ARB compressor to run my locker that is going in this week as well as provide on board air in an emergency. ![]() ![]() ![]()
#10
Well Here are a couple of pics of the ARB front locker installed.
![]() ![]() ![]() Also picked up a Lincoln welder flux core wire model and decided to weld up my trackbar mounts here are a few pics, not bad since I have not welded in 20 years, ![]() ![]() ![]() Also one of it on the RTI Ramp I think my shocks are limiting my travel now.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
